kalynzoo
Jun 16, 2016Explorer
Since you will probably be using park water for flushing you can expect contamination of the water lines to the sinks, unless you stay off the water supply entirely. I would suggest that you chlorinate your fresh water tank after the trip, following the guidelines for sanitizing your tank. It is also possible that the warning if non-biological, such as lead or chemical contamination of the water supply. Again, a complete flushing of the RV water supply when the trip is over seems like a reasonable precaution.
