Lynnmor
Jun 16, 2016Explorer II
kalynzoo wrote:
Since you will probably be using park water for flushing you can expect contamination of the water lines to the sinks, unless you stay off the water supply entirely. I would suggest that you chlorinate your fresh water tank after the trip, following the guidelines for sanitizing your tank. It is also possible that the warning if non-biological, such as lead or chemical contamination of the water supply. Again, a complete flushing of the RV water supply when the trip is over seems like a reasonable precaution.
No, just never connect to a bad water system for any reason. Never could understand not filling the water tank.
