westend
May 18, 2015Explorer
Yup, your cord has a short in it or some part of the copper strands could be touching in the connector body. You may have some continuity from line (+) to neutral if a device is connected in a receptacle but you should have no continuity from neutral to ground or line (+) to ground as these are isolated in an RV in the former and should be isolated in the latter (unless you have a bad device connected in a receptacle).
The chewing mouse theory is gaining ground....
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
