JIMNLIN
Jul 06, 2019Explorer III
I doubt your GM OEM 1/2 ton wheels are rated for those higher pressures. Better check before over inflating them.
I would run them at 55-60 psi when towing and 35 psi when not towing with no more axle load than you have..
My 2500 Dodge/Cummins has the same size Michelin LTX AS LT265/70-17 E and is a much heavier truck than your 1500.
This truck front axle weighs 4220-4280 lbs under the Cummins. I found 65 psi works best empty or loaded.
The trucks rear weighs 2860 lbs empty and anywhere from 5200-6000 lbs loaded depending on which trailer I'm using. I found 45 psi when empty and 70 when towing works out best for this combo.
Once you get the tires mounted drop by a set of scales and weigh your trucks front and rear axles separately....then figure how much psi you need in them.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
