EstorilM's avatar
EstorilM
New 30' TT w/ SUV TV, numbers check
Hey everyone, I've done a lot of the basic math already - but I'm aware that many of you will drill down into every ounce of weight / specs humanly possible, so I figured I'd see if anything jumped out (other than the fact that I "need to buy a real truck." ;)
For starters, this isn't a permanent solution, but things happened very quickly and a couple trips just fell out of nowhere (GF and I will actually be using the TT primarily for our second jobs as sports / event / PR photographers). I wanted to get four good trips this season or decided I'd wait till next year. Well long story short, I found a deal I couldn't pass up on a "used" (brand new) '16 Summerland 2570RL. We decided it was something we'd really try to use, and the smaller units would require a size bump in the near future - so we pulled the trigger on the bigger 2570.
TV is a 2006 Land Rover LR3 HSE (300hp 4.4 V8, ZF 6HP26, 4-corner air suspension)
Not really a typical SUV, some of the numbers are unusual. :)
Curb is 5796, payload 1806, GVWR 7121, GCWR 13,277, tow rating 7700
Trailer weighs 5845 dry, which is exactly how I haul it since the venues we go to have full hook-ups. Only load is photo gear and clothes (we hit walmart for food/drinks there). Tables and chairs maybe - generally 350-400lbs, at or behind the trailer axles, as TW seems high on this trailer vs. the others that I've seen. Propane is in there, but not much else.
One number that's strange to me is the GCWR; if I subtract the curb weight from GCWR I end up with less than the LR3's tow rating?
In any event even if I run with 7481 (GCWR - curb weight) take out the trailer, I'm at 1636. Subtract 400 gear and 80 propane, I'm at 1156. Since we're running with GCWR I subtract people (and dog!) and fuel, say 500. That leaves me with 656, which isn't a lot.
GVWR isn't an issue since the only thing in the vehicle is us and the dog. The above numbers look much better if I just start at the 7700 tow rating and work down from there, like most do - but I'm trying to be more technical and careful.
As for the intangibles, the TV is a tank. Since I bought the TT a month ago, I've put about 1400 miles on it. For the record I've towed many other things w/ it already, from 24' boats to large 2-horse trailers. Also have experience w/ 36-40' rigs, class C, old Peterbilt toter, etc.
The last TT trip included a run through the mountains between KY and VA on I-64 in WV. Used "command shift" the entire time, which actually lets you run all 6 gears (shows # on dash) which is nice. In regular auto it detects loads and knows when/what it's towing, but generally runs the revs much higher than I'd like. Most of the trip was in 5th @ 2-2200, 60-65.
Power was fine, though I did need to go into 2nd once up the main 6% grade. Hit the hill too slow and dumped my momentum, couldn't stay in 3rd, 2nd bumped me up to 4k which was serious overkill, so I just slowed down to 25mph / 3k 2nd and watched the gauges. Even at those speeds I only barely heard the fan start to kick in towards the top.
Braking was perfect, no hint of problems - even on the looong 7% down grade w/ 2 runaway truck ramps. Went into 4th for a bit to help, and bumped up the gain.
Handling is great, tracks like it's on rails in any/all situations, only issue is fast passes by tractor trailers, but I feel like that's always going to give you a "kick" in that case. FWIW Land Rover specifically states that you can't use WD / hitch devices. I'm assuming it messes with the stability sensors. In any event with zero hitch devices it towed like a dream. The air suspension really shined, it didn't matter what kind of high speed dips or the famous expansion joint bridge / repeated bumps we hit, it basically flattened through everything.
I'll probably upgrade to an LR4 (5.0 V8 with extra 75hp) GCWR bump to 14,000, but lower mileage and 4-5 years newer. They also have a trailer stability option that tracks sway with a sticker on the trailer, and automatically dampens / neutralizes it. You can program the length/axle # and have it paint your reverse path on the display is really cool also. I guess the backup is common now, but this was 10yr ago.
Whatever it is, it needs to be my daily driver, and I do appreciate the on-road & snow/off road performance. The only other thing I've really looked at is '13+ Ram 1500s (love the IRS & interior) but finding one (Laramie or Laramie Longhorn) with the air suspension, integrated tow package, and the 8 speed is almost impossible. Last time I looked the dealers wanted ~$52k!
So that's about it - I know I'll take some flak for the TV choice (the looks were priceless though!) but it's all I've got right now and I really have to give it credit, especially at 126,000mi.
  • sch911 wrote:
    You need to weigh the tow vehicle and get the actual weight loaded.
    GVWR - ACTUAL WEIGHT OF TV (LOADED) = WHAT YOU CAN TOW
    This calculation will likely end up being less than the rated tow capacity.
    Don't let this happen!
    Thanks for the reply - I've already seen / replied to that thread. I don't think GROSS weight was an issue there, it was either loaded improperly or driven by an idiot. Sure you can get away with both of those issues if it was pulled by a bus, but I'm not sure if that's good or bad. :)
    In any event, isn't it better to go off GCWR if you have the #, since the MFG is factoring in tow weights?
    GVWR is no issue, as I stated the vehicle is empty minus fuel and us/dog - almost 1000lb under vehicle weight limit.
  • You need to weigh the tow vehicle and get the actual weight loaded.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
