Hartos's avatar
Hartos
New 4" heavy duty bumper cannot fit Rhino drain hose inside
We recently had a new 4" heavy duty bumper fabricated and welded to the frame by a local RV dealer. The thicker steel has caused our Rhino drain hose to not fit inside due to having slightly smaller inside dimensions than the standard bumper. I saw a few videos on YouTube where some recommended using a Dremel to slowly grind down the high spots on the Rhino fittings until it fits which seems like a sewage spill waiting to happen someday with thinner hose fittings. Is that the only way or are there hoses out there designed to fit a smaller inside bumper dimension?
I should also note, i am hoping to avoid a separate PVC pipe attached to the bumper, i see some RV's with that also which may be partially due to this same issue, not sure.
Thanks!
  • Lwiddis wrote:
    Careful, moderate grinding shouldn’t be a problem IMO. Sewer hose leaks are usually on the hose from wear and tear and not at the ends. Catastrophes are fittings coming off.
    I disagree. I've personally never had a hose leak anyplace other than a fitting.
  • Many just strap the correct size PVC under bumper, no rust to deal with.
  • Careful, moderate grinding shouldn’t be a problem IMO. Sewer hose leaks are usually on the hose from wear and tear and not at the ends. Catastrophes are fittings coming off.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
