goducks10
Jun 29, 2014Explorer
Try running the bags around 20 psi. Also you only need 45 psi in your e rated tires on an F150. If you running 65-80 psi then that will make it stiff. Also how are you hitching up with the bags? You need to load the truck with gear and air the bags up to just bring it to the original height in the rear. Then hook up the Reese and set the front height on the truck. Sounds like you just have too much overkill.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
