RJCorazza
Jun 30, 2014Explorer
I have E rated tires and air bags on both my F150 and F250. The E rated tires will make for a harsh ride, but as previous posters mention, a lower pressure matched to load goes a long way in smoothing things out. Unfortunately Ford does not believe truck owners are capable of reading a load chart, and my particular F250 low tire pressure activates at 50psi. YMMV
As far as the air bags, I air up to match about 1/2 of the additional weight. No other reason than to spread the load over the OEM suspension and air bags. The F250 bags support about 15lbs per psi, so when towing I air up to about 30-35psi, 10 psi unloaded.
I also have front air bags that get 50psi when the 800lb plow is on, which makes a HUGE difference.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
