noteven
Jun 30, 2014Explorer III
Rge E tires will decrease rock damages etc. but they are stiffer tires...
Weigh your truck empty and run minimum recommended pressure for your truck's weight found on the Tire and Rim Association Load & Inflation Table -
example Information and Load and Inflation tables
When we ran rge E tires on the rear of our 3500, we ran 40 psi empty truck, max sidewall psi fully loaded truck. The tire had pretty much the same shape and footprint when pressure was matched to the load.
Weigh your truck and trailer loaded ready to go and set tire pressure at minimum according to the tables then make small increasing adjustments if you want.
When we had springs/air bags - air bags at 5 psi empty truck, and maybe 30 psi at max axle load 6199lbs to level the truck so it steered properly.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
