Wishin
Jun 30, 2014Explorer
I suspect part of it is the tires, especially if over filled with pressure. You won't need 80 psi in them, maybe 50?
You probably only want 5-20 psi in the air bags. Air bags can definitely complicate the set-up of the w/d hitch. Each time you adjust the bags, you have to re-do the hitch set-up to some extent as it changes the geometry of the bars to the trailer.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
