93Cobra2771
Aug 05, 2014Explorer
With your bags aired totally deflated, measure the height of your rear fenderwells.
When fully hooked up with spring bars engaged and air in your bags, measure the height of the rear fenderwells.
Height of the fenderwells SHOULD NOT be any higher than unloaded height.
My guess is that the new tires, plus possibly a bit too much air, is making it ride rougher than you are used to.
You need to also remember that your WDH will need readjusting due to the change in rear ride height from the bags (unless the height isn't changing at all). Change in rear ride height changes the amount of angle between TT and TV, which removes some weight off the front of the truck.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
