tcp
Aug 22, 2014Explorer
Fyi: the firestone airbags are rated as 40lbs of weight capacity per psi. at 40psi you've stiffened your rear springs by 1600lbs. that is a lot. i run mine at 8 psi unloaded to support my topper and 18-20psi when towing.
f250s with E rated tires have specified 50 psi as a front pressure in the past with the rears set as required for the weight. not sure if they still do this now.
i would try all the tires at 50, the airbags at 20, and adjust the wdh so the front stays at normal ride height.
2009 XLT (XTR pkg) supercrew 5.4l 6sp 6.5ft bed.
90k miles, Raider Topper, Ride Rite airbags, Ford well liners, 5Star SCT Tune, NGK Iridium IX plugs, Bilstein 5100s all around.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
