VegasScotty
Aug 22, 2014Explorer
tcp wrote:
Fyi: the firestone airbags are rated as 40lbs of weight capacity per psi. at 40psi you've stiffened your rear springs by 1600lbs. that is a lot. i run mine at 8 psi unloaded to support my topper and 18-20psi when towing.
f250s with E rated tires have specified 50 psi as a front pressure in the past with the rears set as required for the weight. not sure if they still do this now.
i would try all the tires at 50, the airbags at 20, and adjust the wdh so the front stays at normal ride height.
2009 XLT (XTR pkg) supercrew 5.4l 6sp 6.5ft bed.
90k miles, Raider Topper, Ride Rite airbags, Ford well liners, 5Star SCT Tune, NGK Iridium IX plugs, Bilstein 5100s all around.
Absolutely spot on! This is exactly what I discovered, 25PSI in the bags was by far the best feel for me. By your math (and I didn't know the 40lbs per pound rule) 25PSI equates to 1,000lbs and my TW is right on 1K.
Thanks for the confirmation, sounds like we're all on the same page. :)
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
