See if this helps any.
I went out and looked at my ball coupler. This is the one I have.
http://www.shelbyindustries.com/custdocs/class%20iv%20a-frame%20coupler.pdfI also took a number of dimensions to make a drawing of the coupler cross section. This was in an effort to help sort out if this top dome plays a role in removing some force off the latch by the Anderson WD system. After seeing what is in these pics I came to a conclusion without the drawing.
The top dome is 1/4" above the top of the latch area. You can see this in this side view.
Here are some other shots of the coupler.
Latch open
Latch closed
Front view
Side view with tow ball in place and latched. I also measured the clearance up and down and front to back when latched. Both where 1/8" total movement.
Now the views that where convincing to me of what would occur when hitched up and WD engaged.
A side shot with the tow ball next to the coupler. Notice the flat spot on top of the tow ball. Every tow ball I have in 2 5/16" has this flat spot. I do not know if every 2 5/16" ball has this, mine do. That flat spot will play a key role in the next pics.
Two side shots mocking up how much engagement at the top of the tow ball will have with the Anderson WD hitch pushing the coupler forward and pulling to tow ball to the back of the latch area.
And 1 more
From those last 2 pics I have come to this conclusion:
- The flat top tow ball eliminates approx 3/16" of the top of the ball sphere from touching inside the ball coupler.
- 1/8" of vertical clearance exists up and down with the coupler latch.
- If the ball drops 1/8" down from clearance plus the 3/16" flat top ball, there would be no dome engagement if the ball is pushed down and back into the latch.
- The back of the ball sphere and the back inside of the coupler dome are curved and create a very good sliding cam angle of the 2 parts in relation to each other.
From the above bullet points I conclude:
A 1,400# tongue weight creates a 1,400# downward force to seat the coupler on the ball.
For a tongue weight of 1,400# the Anderson WD hitch could produce between 6,000 to 7,800# of force pulling on the bottom of the chains. Even if it was 4,000# as Anderson stated in their video it would not change the conclusion.
The higher WD chain force will overcome the tongue weight pushing down. The TT will cam up on the back side of the tow ball and create the 1/8" clearance up top. The TT tongue will lift up the 1/8"and combined with the 3/16" flat to ball, there is no dome engagement left. Almost all 6,000 to 7,800# of WD force pulling on the tow ball will be transferred into the safety latch.
This is my conclusion from what I saw tonight. Anyone see something I missed in this theory to change the outcome?
Thanks
John
