HI Lady Fitzgerald
I'll try and comment on some of your questions.
Lady Fitzgerald wrote:
1. Has anyone factored in the weight of the tongue pressing down on the ball, countering the force trying to pull the latch into the ball?
Yes we have however we may have not explained it well enough. We do not yet have a confirmed set of forces in the chains on the Anderson unit for a known TW on a known TV wheel base and the TT ball to axles distance. Anderson had mentioned on the Forest River forum they where going to post weights this week. As of this note they have not yet. Here on
page 2 I posted possible chain tensions for my camper with a 1,000# TW and my actual 1,400# TW.
They where estimated as 5,700# for the 1,000# TW and 7,800# for the 1,400# TW on what I considered acceptable WD on the TV. Anderson stated in their video at the SEMA show that they like to compress the springs 1/4" which gives about 2,000# of force on each chain. They never stated what TW that lines up with, what TT ball to axle distance or what TV wheel base or ball overhang. Or what they declare proper WD as.
All we know is they are creating 4,000# of force in both chains pulling the TT forward into the back side of the ball coupler. Even using their numbers for what ever TT & TV they line up with the chain force will over come any average TT tongue weight pushing down. With the Anderson WD hitch the only down force into the tow ball is the raw TW.
How do you see that the TT tongue weight will overpower the WD chain force?
Since the ball does not rotate in the coupler (or very minimally at worst, not enough to create a wear issue), wear on the latch won't be an issue. Assuming pressure from the tongue weight does not pull the ball away from the latch (I'm thinking it will), the only time the full pressure from the hitch will be against the latch would be when it is static. As the trailer moves forward, any pressure on the latch (assuming there is any) should be reduced or removed from the latch.
You are correct that rotational grinding wear on the latch will be low to none.
As to the latch being under pressure, this again comes back to the high forces in the Anderson WD chains. The chain force is high enough that the TV pulling the camper will not overcome the WD chain force. Ron G. showed this
hereThe tow ball will stay lodged into the ball coupler saftey latch under the conditions we could think of.
Did you see some other way that the TV or TT could over come the forces in the WD chains?
3. (OK, I lied about only a couple of thoughts.) In any kind of hitch, the latch would have to take the entire force from the tow vehicle when backing unless the tongue weight is countering some or all of that force by forcing the dome of the coupler onto the upper curvature of the ball (as, again, I feel it does). Since hitches don't normally break when backing, I feel the concerns for the hitch latch when using the Anderson WDH are exaggerated.
If you are backing up with a conventional WD hitch installed and WD engaged, the forces down on the coupler are much higher then the TW itself. The WD adds more force pushing down on the tow ball. Since a TT on large OD tires on hard surface road does not take much to push forward or backwards it may be possible for the slight top of the tow ball to still stay engaged in the coupler dome. The latch may never be touched or seldom touched.
If you where backing up a trailer with no WD hitch engaged it would be easier to slip the ball back into the latch. Again the trailer rolls so the force is not a lot to push the trailer.
It is not a stretch on a light weight trailer with no WD to jerk the truck back and the coupler latch takes a hit.
In the case of the Anderson the WD chain force is so high that if the trailer is still able to roll I do not see it ever taking pressure off the latch going forward or reverse.
Ron G has found where when a coupler is rated in accordance with VESC V-5 and SAE J684 that SAE J 684 states the latch area can handle the same forces on a lab bench in forward or reverse and not seperate from the ball.
Up until the new Anderson hitch, most WD hitches allow the trailer to be pulled by the ball coupler front portion. The Anderson has changed that concept. The trailer is now be towed by WD chains with high forces against the coupler latch. While we have decades of trailers be pulled by the front portion of a ball coupler, we do not have so many being towed with high constant pressure up against the latch mechanism. That is part of what all this conversion is about.
If we understand the SAE J684 correct, on a bench test the latch can take the force and not separate from the ball. We do not know if there is latch damage preventing the latch from working properly and freely like we know it does when pulling a camper forward by the ball.
I'll reserve making a complete assessment of the hitch until I can connect with Shelby Industries on if they agree that towing my camper with these high loads pushing on the latch all the time is something they have field tested and are OK with doing so.
I don't have a trailer handy to do this right now but has anyone tried to back a trailer without the latch being engaged? That would give an idea of how much effect tongue weight would have on countering the sideways force being exerted.
I am usually up for a hitch experiment however backing up my TT with the latch not seated is one I will pass on. If I jam the latch and bend it, (my luck it would do that) I have to cut the coupler off as I cannot change latch parts on my brand coupler. However I have experimented with a tow ball being held up inside the coupler and pushed forward and back on it to give me an idea what is going on when the Anderson pulls on the bottom of the ball shank.
It does not take much force to slide the tow ball into the coupler latch when the tow ball is pushed by hand or when the Anderson WD chains are pulling on the ball.
See this pic mocking it up
The red line on the top left shows the angle of contact. With the coupler latched the Anderson WD chains pull the TT coupler latch into the back side of the ball as the TT rolls forward. The angle helps cam it in there. The coupler will slide up and lift until all clearance is gone in the vertical direction. On my coupler that clearance is 1/8". When the WD chain force exceeds the TW the coupler will lift up. That is the key understanding. The chain forces are a lot higher then the TW force pushing down.
There is then almost no engagement left on the top of the tow ball sphere with the coupler dome. The ball will just stay wedged in the bottom rear side of the latch until the WD chain forces get low enough for the tongue to drop back down. If the WD forces in the chains ever approached closer to the TW or the TV pull forces ever overcome the WD chains then the ball coupler front portion will start towing the camper again.
Hope this helps
John
