2manytoyz's avatar
2manytoyz
Explorer II
Dec 02, 2022
New Jeep Gladiator TOAD
I recently modified my new 2023 Jeep Gladiator Rubicon so it can be towed behind our RV (which is changing soon).
The wiring was more complex than the two previous Jeeps I wired as TOADS. Part of it was due to the CANbus system, and LED tail lights with lots of wires.
The RoadMaster EvenBrake system needs a 12V input when the brakes are applied to determine the brake press was successful. The new vehicle no longer uses a basic switch on the brake pedal. It's now a potentiometer so the vehicle can determine how much pedal is being applied. Not a simple mechanical system.
I purchased a brake controller harness, and plugged that into the hidden plug in the dash. I have the tow package, so the wiring was there already. The plug provided a +12V signal when the pedal was pressed, along with a constant +12V, and a ground. This was used for the wireless module. I ran a dedicated cable from the battery, to the braking system with the compressor inside.
It tows flawlessly. Tracks well, with only one slight quirk. Once we arrive, and disconnect the Jeep, the factory TPMS in the Jeep becomes unavailable, and gives an error. Once the Jeep is driven over 15 MPH, each wheel sensor broadcasts, and the system starts registering the pressures. Within a minute or two, all is well.
This vehicle has a push button start. The first step to waking up the computer, is to step on the brake. My theory is each time the pedal is pressed by the aux braking system, part of the Jeep's computer system is activated, but not all of it, causing a fault. Each tail light wire uses a diode, so it isn't backfeeding the wiring. It's not a big deal, and I've talked with another Gladiator owner, using a different wiring kit (Blue Ox vs. my RoadMaster), and noticed the same thing.
  • Thanks for sharing. Sad that the new Jeeps got so complex but does sound like the manufactures adapted and addressed those challenges.
    I am still loving my 2011 Wrangler, but I came real close to buying a barely used 2021 Mojave Gladiator, but like MetalGator when I look now I realize how much I like my no monthly payments Jeep ;)
  • Thanks for posting this. I currently tow a 2015 Wrangler but I also have an older 1/2 ton Truck. I have been thinking about selling both and getting a Gladiator. But I keep getting sticker shock! :)
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 08, 2025
