Bigimac's avatar
Bigimac
New to boat trailers … need some help
Apologies in advance for all the questions … hope this the correct forum … been reading everything about boat trailers & need some expert advice.
Got a new Pontoon last week - weighs in (CAT Scale) at 5,760 with a near empty 50 gal gas tank; so I'm thinking 6,200 is a good loaded baseline weight.
I am towing throughout the inter mountain west, up & down 6-8% grades; 60% interstate, 40% state 2-lane highways. I tow at 60 mph. My 2015 Chevy 3500HD crew cab 4x4 gasser is pulling truck, camper, & boat just fine at a 16,800 GCVW; albeit at 8.1 mpg ;).
The trailer from the dealer is a tritoon 27' and configured with:
- dual axles rated 7000# (3500# each axle)
- aluminum wheels (can't find a rating stamp)
- ST205 14 "C" load tires (2-ply rated 1,317#)
- surge braking
- 7" drum brakes on one axle ... sigh ...
- single leaf springs on each wheel with the equalizer thingy
Need some advice:
1) axles at 7000# seems sufficient
2) Planning on changing wheels to 2200# rated mag wheels; should I consider larger than 14"?
3) The trailer guys can put 4-ply "C" load rated at 1980 lbs & tell me this is good enough; should I listen to them?
4) I want to use the built-in brake controller & ABS safety features of the truck ... & really don't like surge anyway, so, it's electric versus EOH; trailer guys say electric is just fine; champion trailer & west marine web sites seem to lean to EOH; suggestions?
5) The tow truck has 14" brakes and adding 7" brakes to the second trailer axle "seems" to be enough; do I need to consider moving to 10" brakes?
6) Drum versus disc - a bit of a toss up on web sites, with disc being a bit more popular for the weight & maintenance considerations; suggestions?
7) Last weekend on a "break in" 500 mile trip, the boat really bounced around (no sway though) on the less smooth 2-lane roads. Do I need to add a spring (or two) to each wheel?
Thanks some more for any advice or suggestions - I really do want to get this done safely & as right as possible - cheers!
p.s. I did flip the hitch ball so the trailer now is way more level than in this picture …
  • I had a 27' JC Evolution tri-toon with 14" rims. I had Kumho 195R70/14 "D" rated tires with dual axle disk brakes(surge). Pulled with a 2500HD without a problem. Don't think I would go bigger tires due to clearance issues but would recommend A "D" rated tire. Hankook radial RA08 in the 195R70/14 "D" rated woud also work. They both require 65lb psi. I would at least go to the higher rated "C" tire.
  • newman fulltimer wrote:
    titan has eoh for that trailer taller tires means you need deeper water to get into to launch.
    thx - hadn't thought about launching - good one
  • titan has eoh for that trailer taller tires means you need deeper water to get into to launch.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
