rk911
Aug 21, 2014Explorer
gmatti wrote:
We recently traded our Dually and 5th Wheel for a 32' Class C Mini-Motorhome. Of course now we are faced with towing a "toad" and do we go 4 down or dolly? When I try to analyze which is best they come out pretty much even but maybe I am missing something?
It seems that the costs are about $1,600 for a dolly vs about $4,500-5,000 for parts and hook up for flat tow. My F-150 is probably a little heavy to tow and my wife's Volvo is completely untowable at least according to her owners manual. We also have a 2004 Buick Century that weighs about 3,400 but the manual says no flat towing. So it appears we either need to trade the wife's Volvo for something that can be flat towed or go the dolly route. It seems to me that the dolly route might be better anyway considering the costs difference and the utility of the dolly for any vehicle that can be dolly towed. Here are some of my questions:
1. When dolly towing are the lights on the dolly sufficient or do we need additional lights on the vehicle being towed?
2. Surge brakes or electric brakes?
3. Do we need a brake controller in the vehicle being towed?
4. If we always go for pull-thru sites is storing the dolly really an issue?
5. Should we can the whole "toad" idea and just get a scooter to carry on the back of the motorhome?
We are probably missing something so any help will be appreciated. Thank you, Jerry
let me take a whack at this.
1) If by 'sufficient' you mean legal that will depend on the state. while we don't tow on a dolly when we looked into that option back in '03 we decided that having extra magnetic lights on the back of the toad was not a bad thing.
2) I prefer a brake system that utilizes the toad's own power brake system and which is not dependent on a cigarette lighter plug for power. we use the Unified Tow Brake from US Gear.
4) The dolly will always be at least a minor issue. with a long enough pull thru you should be able to back the toad off the dolly and leave the dolly attached to the MH.
5) I wouldn't. Scooters are fine in their place but you may run into situations where you'll wish you had doors and a roof.
weight is your enemy and a dolly will add weight. in my opinion before you do anything you need to determine the GVWR, GCWR and GAWR's of your class C. pay special attention to the gross axle weight ratings. then load up your class C as you would for a trip...food, fuel, water, LP, supplies, clothing, pets, people and other stuff...and take it to a certified scale. get individual axle weights.
next, compare the individual axle weights to the GAWR for each axle. as long as the axle weights are less then or equal to the GAWR you'll be good to go otherwise you'll need to offload weight from that axle.
the sum of the GAWRs should be less than or equal to the GVWR.
next, determine the weight rating of your hitch...it's likely to be rated at 5000-lbs but double check.
now you're ready to determine how much weight you can safely tow. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
* the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
* the weight rating of your tow bar
* the weight rating of your hitch
good luck.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
