js415's avatar
js415
New Trailer gives a Harsh Ride!!
I have been towing a 2014 Coachmen Travel trailer for the last 4 years with my Chevy 2500HD and have for the most part enjoyed a fairly smooth ride.
The Coachmen weighs in empty at 6400lbs, so probably around 7400lbs or so loaded.
Whether on interstates or side roads, we have always had a smooth ride.
Yesterday I picked up our new Heritage Glen travel trailer. This one weighs in at 8500lbs empty. So it's about 2000lbs more than the other.
I used my same Equalizer brand hitch and we set it up at the dealer. Basically the height was almost the same, so very little setup was needed.
With the trailer loaded, the rear of my truck only dropped 2" from its unloaded height.
It pulled just fine,, although I could tell the extra weight was there.
What was not expected was the harshness of the ride. I could feel every bump and crack in the interstate. Every joint I hit seemed to just "jar" the truck.
Not sure if this is what I should expect, or maybe there might be a few folks with some suggestions on improving the ride. I only drove it home, about 60 miles, so not a lot miles on this setup.
Thanks,
Jerry
  • I have a 2015 Chevy 2500HD and my camper weighs in close to 9,000Lbs. loaded. I have a very smooth ride although like you, I know there's a 9,000Lb brick behind me. I don't think it's your camper weight. The 2500HD is plenty of truck for the camper you have. I'm no expert but I would make sure my truck tires are properly inflated, my weight distribution is correct and my tongue weight is within the acceptable range.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
