cannesdo's avatar
cannesdo
New Trailer Tires... Goodyear v. others?
I have a heavy trailer and get nervous about the trailer tires. They're G-load. Goodyear. Got them after one blew up in rush-hour traffic in L.A. four years ago. Now that I'm looking again I'm learning that the Goodyear are twice the price of the others I've had quotes for (Solid Track from Big 'O' and Vision Load Boss). Your thoughts? With a heavy trailer will these other two do the job? Would they just not last as long? What is Goodyear giving me for twice the price?
Also, half the people who look at them say they have wear left. I hate the guessing game. They're 4 1/2 years old. Not a lot of miles on them and covered for most of that time, no cracks or anything but it still makes me nervous. ? I'd almost rather sell the old ones used on CL and get all new tires for myself just for peace of mind.
Just looked at the photo I took of the one that blew up in L.A. It was on the trailer when I bought it. It was a Good Year also. Do they have different load ratings? Is a G a G? Or are there different kinds of G's...steel wall, not steel wall...
Also, I have 265 75/16s on my truck right now and just realized that the plate on the door says it should have 235 85/16s. ? Les Schwab put those on for me 4 years ago and didn't mention the difference in size. Is that a problem? Should I go back to the 235 85/16? Is one or the other better for towing?
You know.....I just checked the tread. What's freaking me out mostly is that these tires are 4.5 years old. But they don't have much in the way of miles on them. Only about 6K really. The sidewalls look great -- like nw -- and I still have 1/4" of tread. And like I say they've been covered for almost all of that 4.5 years. And 18 months ago I painted on that solar screen stuff. Think I'm ok? I'm heading to Santa Barbara for the summer, then back to Mesa AZ next fall.
The tires were in heat for about 2 months. The rest of the time was MT (one winter there)...2 years in San Diego, a few months on the Oregon coast.
  • For my trailer tires I never judge them by the way the tread looks. Last year I put 5000 miles on my TV. And had the tires installed January of 2014. The reason why they were put on was not from worn tread but some small cracks on the sidewals.
  • cannesdo wrote:
    Do wider tires offer more support/strength for towing? The 265/75/16's look fine on my truck. Is this a common thing to go with that size tire on a Ford Superduty? Even though the specs show it should have a 235/85/16?
    Ford used the LT235/85-16 at 3042 lbs capacity for years. The LT265/75-16 tire at 3195 lbs capacity has the same tire diameter and is one of Fords OEM sizes now.
    Oh... and by the way the Goodyear G614 RST is rated at 75 mph on their web just like the Sailun S637 LT G.
    The Sailun S637 are actually more popular with haulers because of cost issues and the G614 past performance issues and the S637 is a all position tire for truck or trailer unlike the G614.
    No more miles than you tow the trailer either tire will work fine.
    I run my LT tires on my different trailers for around 7 years which is usually around 50k-60k miles before selling them and buying new ones.
  • Terryallan wrote:
    4 year old Goodyear Marathons? You are on borrowed time. I will never own another set of GY tires. You pay extra for the name, and get less.
    Were I you. I would try to find some Maxxis tires, IF you are sticking with trailer tires, and not going to a truck tire. Maxxis is generally thought of as the best ST (trailer tire) on the market.
    Goodyear "G" tires are not Marathons. I put over 70K on two sets of Goodyear "G"s with one blowout that was probably due to a leaking valve stem but Goodyear paid for the damages. I have heard that tires that set for long periods can deteriorate because of the lack of use prevents the internal "chemicals" from doing their job in lubricating the tire. (I don't know of another way of putting that.) Again that's what I've heard but haven't attempted to check that out.
  • 4 year old Goodyear Marathons? You are on borrowed time. I will never own another set of GY tires. You pay extra for the name, and get less.
  • I would not hesitate to run the GY G's 6 years and possibly more! They are a great RV tire also with the GY H's.
    4 sets of GY US Made tires from e's to H's and never even a flat all with many thousands of miles. Even towed with each set 75+ in HOT weather.
  • Do wider tires offer more support/strength for towing? The 265/75/16's look fine on my truck. Is this a common thing to go with that size tire on a Ford Superduty? Even though the specs show it should have a 235/85/16?
  • It looks like best option is the Goodyear G614. 2nd best: Sailun S637 But the latter is only speed rated for 75 mph. v. the Goodyear's 106.
    Not sure I want to chance any of the Chinese tires. Can't find a single review on line for the Solid Trac or the Vision Load Boss. Does anyone have any experience with these last two? The Solid Trac has a higher speed rating than the Sailun, more on par with the Goodyear.
    In 8 years I've had only Goodyears and the only blow-out was when I knew one tire was too low (back before I knew they had small compressors that could handle the 110psi). I was looking for a truck stop when it blew.
    Any other low mile/aging anecdotes on the Goodyears?
  • Tires--
    Have always used Good Years "G" rated tires with good luck. At 5 yrs. I replace my trailer tires regardless how many miles are on them. While there may be some individual cases where people have used tires that are over 5 yrs. old, I think that most tire Mfgs. agree that after 5 yrs. you are a tire problem waiting to happen.
  • Thanks Joe,
    I thought with H-load you had to switch to 17.5" wheels. No?
  • After 2 tires on one trip - and the tires were only 2.5 years old, I went with the 225/75/16 Uniroyal Laredo HD/H Tires on 16" wheels, and I couldn't be happier.
    http://www.uniroyaltires.com/tire-selector/name/laredo-hd-h-tires
    Hope that helps,
    Joe Zeppe
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
