Need-A-Vacation's avatar
Jul 12, 2015
New WD Hitch Needed- Reese DC or SC?
We are very seriously considering upgrading to a new trailer, a Jayco 32BHDS. Listed dry tw is ~900lbs, so I am figuring after propane and battery, close to 1200lbs + what is loaded in the trailer, so looking at 1500lb bars.
Main question I have, is do I go with another Reese DC, or maybe the Reese SC system? I would consider the Equal-I-Zer system, but if for some reason we change trailers down the road, I can just change bars without buying a whole new system. I also like how the Reese has more angle adjustment than the Equal-I-Zer does.
I know what is involved in setting up and adjusting both the DC and SC systems. Our loading doesn't change much. So, if you were to do it over again, which system would you go with between the two?
I guess my one concern (maybe crazy!) with the DC system is how the cam arm brackets attach to the frame. I know there are a lot here who have not had nay issues. While crazy and old school, I just like how the original model attached with the u bolts.
I will get the 2.5" shank if we do buy the 32BHDS. Anyone happen to know the coupler height of the trailer?
TY!
  • It seems that many owners of that model report closer to 1400 pounds of loaded TW, so you may want even larger bars.
    My dual cam is great when adjusted correctly. 75mph rock solid. When it's off, 60mph is scary. If you don't mind adjusting correctly, get another one.
  • You will want the tongue weight to be about 12% of the trailers loaded/ready to travel weight. that is regardless of what is loaded on the tongue or the dry tongue weight. you need to load the trailer properly to arrive at that TW number!
    I`ve had the DC HP (bolted to the frame) for 10 years now and it has performed great!
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
