dmoney316's avatar
dmoney316
Newb question regarding max towing, GCWR, and WDH
So, we're new to the game, but much like everything else i do, i go all out. We went from tents to a 2009 Trail Sport TSE191. I just got my 2017 Nissan Pathfinder SL with factory Class III Tow Package. Now from what everyone is telling me i should be fine. I have a GVWR of 5981 lbs for the TSE191, and i can pull 6000# right???Seems right to me, especially considering i can't imagine filling the camper with almost 3000# (it has a dry weight of 3090#)
Nissan user guides says the following.
A weight-distributing hitch system (Class IV) is
recommended if you plan to tow trailers with a
maximum weight over 5,000 lbs (2,268 kg).
My buddy says ireally shouldn't need the WDH, but the guy i got it from says I really should get it and he'll even set it up for me.
So, considering i CAN fill my camper up to go over that limit, do i need the WDH? I can't even see myself filling it with 1500# of stuff let alone 2000#..
Also, Nissan has given a GCWR of 10,000#. The problem there is that the truck without any payload is over 4500# Figure at least 500 more for passengers and cargo, so we're at 5000#. If i do decide to go after my 6000# towing capacity they say i can handle, that's over 11,000#, well above the 10,000# rating they give me.
Sorry for the newb questions, but i just want to be safe, and if getting the WDH means i won't have any problems then i am ok with that, but t seems to me that i may be over my head a bit here.
TIA
  • Get the SUV weighed loaded ready to travel. That includes family, pets, and a full tank of fuel. Subtract that number from the MFGs GVWR number as found on the drivers door post. Now, take the trailers GVWR and using 12% of that number. Is this over or under your available payload number? My guess your going to be over.
  • thanks. I know the numbers i posted are all over the place, and that's what troubles me. Nothing seems to add up. My problem is that i don't have the trailer yet, and can only go by the numbers that Nissan gives me, and what the trailer manufacturer gives me. Worst case can i go pick up the trailer with just a basic ball hitch and find a weigh station somewhere? Not even sure where to find that in the Montreal area.
    Thanks,
  • You have posted numbers all over the place.
    "017 Nissan Pathfinder SL with factory Class III Tow Package" - "weight-distributing hitch system (Class IV) is
    recommended"
    Get every thing weighed. (look up previous posts on weighing your truck answer TT)
    then post here again. Everything will get much clearer then.
