k6ncx's avatar
k6ncx
Newish motorhome, very dirty oil
Forgive me for being an ignorant newbie, but I've got a question about my motorhome'S engine oil.
The rig in question is a 2016 Thor ACE 30.1 (bought new in September, under 5,000 miles and 125 engine hours on it now,) but I don't think the answer is specific to any brand or line. It's built on a 18,000 lb gross Ford F-53 chassis but, again, I don't think the answer is going JG to depend on that.
When I checked the oil last week, it was at the low end of the OK range for level, but I was stunned at how dirty it was. It's not due for an oil change yet "by the book" but I think I'm going to get one.
It is that enough? Should I be concerned? Should I make haste to a Ford truck dealer?
  • The simple thing to do is like I'll do with another track rig I'm acquiring. What I'll do is change the oil twice. After the first change I'll run it for about an hour and then change oil and filter again. After that I'll watch it to see what the oil does. If I have concerns, I'll get it tested. Oil and filters are cheap way to fix any concerns.
    Bill
  • At 5k miles it's time for an oil change. Change it every 5k. I do my V-10 Excursion every 4K miles with mobil1.
  • Change the oil, it's cheap insurance.
    If in doubt, have it analyzed.
  • Did the original owner change the break-in oil after the mileage indicated, or is that the original oil?
  • That motor probably still has the break in oil in it. Sounds like it's been abused. Start figuring out what it's going to take to get a new engine. My guess it's on it's way out.
  • There is no such thing as break in oil. but most people will tell you to do the first oil change early to get out any impurities, which cant hurt to do. fact is all newer motors are so well built that there is no machining impurities in it. change the oil and continue with scheduled oil changes. if you don`t drive it much once a year is sufficient. change it when it goes into storage and it will be ready to go in the spring!
    If dirty looking oil meant the engine was toast, I'd lose several engines a year. Idk how one can qualify a statement like this^.
    My sno bike oil looks like a dirty milkshake and smells like race gas after every ride, nature of the beast. (Although I'm working on an engine cover to keep temps up and reduce over fueling more)
    My boat oil looks worse after 30-40 hours than the car at 5000mi. It is and will continue to run fine.
    Truck (diesel) is black before you can blink.
    To the OP, change the oil and don't worry about it. Besides, it's under warranty anyway, right?
  • Look at the Ford owner's manual.
    My GM product to service at a more frequent interval under severe use. My rig is close to gross weight, so I change according to the chart for severe duty.
    This should include all portions of the drive train, engine, transmission and differential.
  • Turtle n Peeps wrote:
    You can't tell by looking at oil what kind of shape it's in. Just because it's black does not mean it's bad. Just because it amber does not mean it's good. The ONLY way to tell what kind of shape the oil is in is with an oil analysis.
    TRUE !
    Black oil means it is doing its job.
    There is no break in oil anymore and at only 5000 miles on the engine its just now due an oil change. No need to scare the OP with false info.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
