LadyRVer wrote:
When I had that "trailer not connected" error message, I was told to look inside the trailer plug and make sure those contacts were pinched together (the one for the brake wire.) Used a pair of needle nose pliers and brought them together more. I also cleaned and greased with die-electric grease before doing that. Worked after that. Might be worth a try.
I shall try. I did check as much as I could, did pinch them to make sure they made good contact. Haven't tried die-electric grease. Did try plugging and unplugging several times.
This this has me stumped. :/
I appreciate the thoughts.
