crazyro wrote:
Gdetrailer wrote:
crazyro wrote:
Beaker wrote:
Factory integrated brake controller on my truck was causing same message on mine.
Argh. RAM apparently has had some issues with this. I just tested the truck 7 pin and with brakes depressed or brake controller fully engaged, I'm only getting 1/2 V on the ground and brake pins.
What was your solution?
Guess I should have also read page 2 of this thread..
The only way to troubleshoot and diagnose a IBC problem is to drive around with a trailer connected or build a test rig with resistors and lights and a meter that present enough load to trigger trailer connected response and drive around..
Thank you for all that information! I truly appreciate it.
I'm going to borrow a friend's camper tonight and will hook up to it. If truck detects it, then I know the issue is with my system. I will definitely follow through on all the suggestions and try all I can before taking it in (last resort).
Much appreciated.
You bet!
Rock Hill, SC? Been past that area many times over the yrs, take a run to MB and then head over to Spartanburg SC to visit my Cousins there typically once a yr.. I would lend a hand at troubleshooting but that is a healthy trip from PA.. Not to mention the virus thing sort of clipped our trip plans last yr and possibly this yr.
