cummins2014 wrote:
Cummins12V98 wrote:
When I did a EOH brake system on my Boat Trailer I would get an intermittent no trailer connection "NC". It drove me crazy till I just happened to touch the ground wire while looking for a bad connection and noticed I had not tightened the bolt fully to the frame. Snugged it up and all was well!
Bingo, was hoping someone would mention ground, had the same issue . I was looking to see if the OP mentioned checking the ground, he did mention getting the ground thru the ball, not a good way ,it will be intermittent no trailer connection ,been thru that also, I assumed I was getting a good ground thru the ball .
When I realized I wasn't getting a good ground on the trailer , I connected a separate wire to the trailer ran it alone the the other wiring, and connected inside the plug where it belonged , all was well then . IMO the OP is not grounded well enough .
To the OP ,do you get intermittent " NO TRAILER CONNECTION " ??? Also you did mention you see no ground wire ???
I looked all up and down the trailer for a ground wire hooked onto axle or frame but didn't see one - that's why I mentioned ball as I know some trailers use it for ground (and have read that it's not a solid connection). I may just have to open the box and run an additional ground wire.
