Gdetrailer wrote:
cummins2014 wrote:
Is it possible for the grounding on the brakes on this trailer the OP has to be faulty, letting the lights work, being on a different ground ???
No.
First, somewhere in the thread the OP already established that they did not have trailer hitched to vehicle and their lights do work properly.
Pretty much eliminates a ground wiring fault.
Not to mention IF there was a ground wiring fault, I can assure you the lights will not function properly. Typically, you will get some crazy lighting action do to the 12V finding alternate grounding paths.. May not see that as much with LED lighting but with incadescent bulbs you would get say one bright stop light and one dim stop light, things like that.
Rather than blaming wiring, truck, IBC and any other thing, it is much easier to break down the system in block or chunks..
We know that the trailer has a a breakaway system that can be activated without the truck electrical system connected..
So, lets use this to our advantage to help eliminate a bunch of variables..
Pull breakaway pin.
The breakaway switch now sends full on board battery voltage directly to the brake magnets.
Breakaway is supposed to LOCK AND HOLD the trailer brakes in a "on" position to stop and hold the trailer in the event that it breaks away from the tow vehicle.
If you attempt to pull forward or backwards with break away activated the wheels MUST not turn and the truck should be able to SLIDE the tires..
If wheels lock and slide then we KNOW for certain that the break away is working, we KNOW that the WIRING (positive AND GROUND) on the trailer is fine and we KNOW that all mechanical brake parts are setup correctly and functioning. In this case then we NEED to look at the TRUCK wiring and brake controller.
If wheels do not lock and slide when the breakaway is activated, then we KNOW there is a fault on the trailer and it is not the trucks issue.. In this case, the fault can be electrical or mechanical or even both.. But none the less we have eliminated part of the system..
Now if it is trailer, then we can further troubleshoot..
We KNOW that each magnet is rated to draw about 3A at 12V, we can use an ammeter in series with the on board battery to verify the current draw at 12V.. Note, there WILL be some variances due to battery state of charge, wiring size and magnet variations but it all should come close to 12A for all four magnets connected together..
should get reading close to 12A for 4 magnets.
about 9A for three
About 6A for two
About 3A for one..
If you get close to 12A for FOUR magnets then you have now eliminated trailer brake ELECTRICAL system..
Current much less than near 12A for FOUR magnets means you HAVE an electrical issue which could be broken/damaged wiring.
If electrical checks out then move on to the brake mechanical..
It is a thoughtful and logical way to troubleshoot and diagnose without randomly jumping to conclusions, blaming grounds, jacking it up or ripping things apart.
And yes, I went to school for Electronics theory including troubleshooting and repair many, many yrs ago, the same steps of breaking the problem down into smaller blocks using divide and conquer logic does work very well on other things besides TVs and Stereos..
Could he just jack up one wheel, then pull the breakaway cable ,and see if locks up the tire, or do you have to establish it sliding the tires across the driveway , which doesn't sound like the best thing to do .
