cummins2014 wrote:
Could he just jack up one wheel, then pull the breakaway cable ,and see if locks up the tire, or do you have to establish it sliding the tires across the driveway , which doesn't sound like the best thing to do .
Yes.
As long as you don't mind jacking one wheel at a time, however, just because the one you picked works, doesn't necessarily mean the other three wheels are working.
That already HAS been mentioned in this thread.
Sliding the tires a couple of feet isn't going to hurt the tires, wheels, brakes or the trailer, but it does give you a real good indication of which brakes may or may not be in good working order all in one quick action..
Additionally, when hand turning a wheel and applying the breakaway, you only have a small amount of strength, far less than what your tow vehicle can apply.. It is possible to have the brakes strong enough to lock via hand but not be as strong as they should be, those brakes must be strong enough to stop and hold the entire trailers loaded weight.. Don't know about you, but myself, I don't think I would be able apply several thousand pounds of torque without resorting to a ten foot pole. Only pulling the trailer forwards or backwards will show just how good the brakes are working. In fact that IS one of the "tests" that my State Inspection mechanic does..
Do the divide and conquer troubleshooting correctly and you can easily bypass a lot of hard work (and guess work)in the process..
