mobeewan wrote:
travelzoo wrote:
enblethen wrote:
Did you check to see if by opening relief valve water comes out of it?
Yes I did, cold water inlet seems to be ok, but I bought 2 check valves and will change both while I have it apart.
You say "both check valves" There is usually only one on the outlet. If you have a brass fitting on the cold water inlet it is probably just a nipple. No need for a check valve on the inlet.
There are check valves on both the cold water inlet and the hot water outlet. So as long as I have it apart I'll replace both valves.
