twodownzero
Jul 27, 2019Explorer
You should try putting as much weight in the front of the trailer as you can. With a properly loaded trailer, a conventional WD hitch would work just fine. In fact, at your trailer weight, you can probably pull on a normal class III weight carrying hitch and it'd pull okay if you had it set up correctly.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
