castledave's avatar
castledave
Noisy RV Rooftop A/C unit
Do all RV A/C units sound like you are standing next to a 747 at full engine run up. The unit does not vibrate. Although one can perceive a difference in the rpm of the blower at low, med, and high settings even low is much to noisy to run for very long. I have cleaned the inside filter.
  • Yes they are noisy but then again it is right there...not outside in backyard on a pad.
    Really noisy.....remove ceiling grill and check function of blower fan wheel (turn fan on with grill removed and watch for excessive movement/wobble) also check duct work leaving discharge plenum (loose materiel, loose ducts etc.)
    And make sure registers are open & flowing air.....restriction will cause noisy fan
  • Ours is kind of like that. If we need it on at night, we run the one in the front so it is less noisy in the bedroom.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
