wanderingbob's avatar
wanderingbob
Explorer II
Aug 06, 2016
Not nitrogen , again !
If at sea level I removed the valve stem from a tire ,the air inside would equalize at one atmosphere .Replace valve stem and brought tire up to 33 pounds with nitrogen , contents would be 50 percent natural air and 50 percent nitrogen , Why 33 lbs , as I understand it one atmosphere equals 33 lbs. Maybe I am mixing apples and oranges .
Continuing , I bring tire up to 66 lbs , operating pressure for this tire . Tire now is one third air and two thirds nitrogen . I can never improve this mixture with out a vacuum pump , nearly impossible because of sidewall collapse .
How far off base am I , I ain't no science wiz .
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 07, 2026
