roadrat57's avatar
roadrat57
O2 sensor stuck lean
Hi!
I own a 2008 Ford V-10 that trips the check engine light at idle - bank 1 sensor 1 stuck lean.
Two possible causes, vacuum leak or mass air flow sensor. I think.
Anyone had the same problem?
Thanks,
Mike
  • Why could it not be an 02 sensor? If the value isn't changing continuously then the sensor or wiring is bad.
    You should be able to look up in you owners manual how often that sensor is to be changed. Some were 30 or 60K.
  • roadrat57 wrote:
    Hi!
    Bad sensor ?
    More likely vacuum leak.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
