mkirsch
Jul 13, 2020Nomad II
You need Amps to actuate the brakes, not just Volts. You can read a voltage, but if the connection is high in resistance, you won't get adequate current flow. As soon as you connect the brakes, the voltage basically goes to zero.
What you are measuring, probably, is a sensing voltage that the brake controller is using to determine if the trailer is connected.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
