Water-Bug
Apr 19, 2015Explorer II
MrWizard wrote:
unless you have water leaking into the TV
you have a capacitor in the power supply that is leaking
one day it will fail badly with smoke and fire
have the TV repaired or replace it
Sounds like Mr Wizard has never heard of a fuse. Can't remember when I last heard of a solid state flat screen TV bursting into flames. Older CRT TVs had high voltage to the CRT and could be a fire hazard but modern TVs are pretty much low voltage and not very suseptable to combustion.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
