Flapper
Apr 19, 2015Explorer
If you google "leaking LCD TV" you'll see that there are lots of people with this issue, from most brands. In quickly reviewing a lot of the entries, most do not give definitive information. A Sony manual states that LCD panels CAN leak, and the liquid is poisonous and can cause skin irritation. See page 7 here:
https://docs.sony.com/release/KDL32SL130.pdf
Another reference essentially said the same thing. It sounds like you have semi-hazardous waste leaking into your RV. I'd advise getting rid of the TV right away, and replace with another!
From what little is out there, cleanup with soap and water is good enough, just wear gloves, and of course do not let the liquid touch eyes or mouth.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
