mtrumpet
Jan 26, 2016Explorer
Larry-D wrote:mtrumpet wrote:Larry-D wrote:
A friend and I wired his new house for cable using exterior coax his brother gave him. His brother worked for the cable company. We ran all the cables in the house to a second floor wall and hooked it all up. Within a couple of years the oil inside the coax started staining the outlet boxes and the sheetrock under the boxes in all the rooms.
Lesson learned don't use coax with oil inside it, inside the house. I tell this to suggest you look at the cable connection on the back/side of the tv. Just in case.
Oil filled coax cable?? What are you talking about?? :h
Exterior cable company coax. The coax had an oil substance inside the cable to keep moisture from getting inside the cable since it was for an exterior application. Seen it with my own two eyes.
Interesting. That's a new one on me.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
