Old-Biscuit
Aug 03, 2016Explorer III
You have a very small leak......
System will NOT lose pressure unless you have a leak
Your description points to pump internal check valve leaking just enough for system pressure to drop to start set point (typically 30# if you have a 45# pump or 40# if you have a 55# pump)
Pump only runs momentarily because it doesn't take much to increase static line pressure to stop set point.
Course it could be a small leak at a hidden fitting also.
I had same issue (short pump cycling) and searched high/low for leak.
I even put toilet paper under/around all suspect places.
Then one day I needed to remove a panel to run a cable for a display and there it was.....small leak at a fitting on low point drain line.
If we hadn't been in a place with HARD water I probably would still be wondering where/what it was. Fitting had white calcium deposit.
Cleaned it up.tighten........no more pump 'burrruuup'
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
