D_E_Bishop
Aug 05, 2016Explorer
I'm going to go along with the air cushion and slight leak in the check valve. I had the same problem and rather than go thru the hassle of R&R the pump and replace or clean the internal check valve I bought a Shurflo check valve with 1/2" barbed hose fitting on both ends. No more burp. Cost about the same for the two valves, about $15 for the add on valve.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 26, 2025
