vesh1717 wrote:
bfast54 wrote:
How hot is hot,..........?????
if you saw the " wheel wobble "........and that side.... is significantly hotter than the other side ,then it sounds like your bearings were not done properly or are loose.
If you're not capable of doing this yourself then find a reputable place and have it checked.
I have no idea how to do this. It wasn't so hot I couldn't touch it, but it was probably similar to a cup of coffee when you hold it.. I dunno, that's the best comparison I can think of. The other side had no temperature at all. The wobble was barely noticeable, but def visible in my opinion.
Sounds like I should bring it to the RV dealership where I got the bearings and brakes done
Unless something happened or broke........ it sounds like you should not have gone to that place in the first place .....Yikes...!!!!......:E
But since you did ,take it back there and have them check it and see what happened....since this was supposed to be done by someone in the know ....please let us know how this turns out....:W
