kyle86's avatar
kyle86
Opinion Needed - Repacking Wheel Bearings and found THIS
I am about to make a long trip so I went to repack the bearings for the first time on my new to me 2003 sunnybrook 5er. The previous owner told me he had to replace an axle due to a wheel coming off at some point. Well i repack the front left wheel first which is the older axle and all is well. I went to repack the rear left axle which is the newer 2012 labeled dexter but found what appears to be significant damage with a possible repair job. The bearings and races look okay but the spindle shaft is marred up and appears to have been partially polished on top like a repair. The washer that goes under the castle nut likewise looks to be damaged or sort of roadside repair as the outside looks ground down to a smaller diameter. Weird thing is it seems to fit the spindle shaft pretty good... I don't know what to do here as this is above my level of expertice. Am I okay to repack the bearings and put back together? It was nice and tight before I removed the wheel. For what it'a worth the previous owner said he replaced the china bearings with timken which it appears he did not lie on that but seems to me something happened he didn't tell me about. How should i proceed?
  • from what your seeing,and telling ,it was cleaned up, and fitted with the best bearings out there, and it was good to go when you took it off, ME,I,d pack it and watch the temp on it at each stop. I,d go on the trip. from your words it sounds safe.
  • read
    http://forums.motorhomemagazine.com/index.cfm/fuseaction/thread/tid/15775751.cfm
    to learn how to post picture
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 25, 2025
