Chock_Full_o__N
Nov 13, 2014Explorer
Bumpyroad wrote:
a ceramic cube heater will put out as much heat, can be, moved to where heat is needed, and the fan noise would be similar to the AC fan but you wouldn't be wearing out an expensive AC fan. if you have ducted air much of the heat from that heat strip will be lost in the duct work. plus I have been in campgrounds that charge extra for electric heat. an air conditioner fan buzzing when it is 32 degrees out will be a clue.
bumpy
All of the above ^^^
We have a pretty much useless heat strip in ours. The first time we tried it out, we were out and about on a very cold day and left the heat strip going to try to keep it warm in the camper. When we returned at 8pm, it was 23 degrees outside and not much higher inside. Thoroughly disgusted, we turned off the heat strip and turned on the little ceramic heater. In just about 20 min that little heater had it nice and toasty-roasty. That was the first and last time I ever used the heat strip.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
