mkenyon2's avatar
mkenyon2
Our first, and last, TT rental experience
I'll post a tl;dr; list below with a summary of our troubles. But here's our story.
We used to tow a Coleman popup, but lately we've been renting cabins. We wanted to get back into having our own RV, and figured renting would let us get our feet wet. So, we reserved a trailer and a spot at a state park. The rental was bought new at the start of the season, and would be sold as used at the end of the season. A 21' Apex Nano.
About a week before the rental, I called with a few questions to make sure I'd have what I needed. WD hitch and ball, check. Correct dates reserved, check. Pickup 9AM on our first rental day, check. That was the big one. They open at 9, and we wanted to pick it up early, so we could load our stuff and get to the campground before dark.
We show up at the rental place about 9:05 AM, the 3rd of 4 families there to pick up at 9 AM. We were in line as we heard the 1st family get told, 'Oh, you needed to call in to set up your pickup time. We'll have that ready in 15-20 minutes.'
I nervously look at our paperwork. I know I had called in, but was it recorded? Our paperwork said 12:00 PM pickup time! :E By the time it came to our turn, we knew what to expect. 'Sorry, this pickup time reservation is new this year and we're still getting it sorted.' Well, you've had all summer?!
So we wait. And wait. And wait. Family #2 was the first out of the parking lot. At 10 AM. Family #1 and ourselves were leaving around 11:15. (Boy, was the garage guy upset when he was told we'd need a WD hitch... which we had reserved and paid for months earlier.)
They had done a walk-through at the rental place, but it was quite rushed... as they 'weren't used to all these folks picking up at 9 AM'. I wanted to do a thorough walk-through, but that wasn't to be. We tried to note anything damaged or out of place, like the one cabinet door hanging off the hinge, or the blinds that were busted, or missing laminate on some of the trim. But they were in a hurry.
So... now we're on the road, back to our place to load up. We get into our driveway, slide out the slide-out (we hadn't done that during walk through) and realize there is dog food under the slide-out and pet hair EVERYWHERE. (We don't mind dogs, but if we're told it's been cleaned, it should be clean.) My wife got to work cleaning the trailer (another 45 minutes) while I went to work figuring out why the fridge was beeping. I have pictures of what was cleaned, and it was filthy.
As for the fridge, it was warm, since it hadn't been running. (wasn't ready for 9AM pickup) This particular fridge will 'run' on battery, but only if it has a propane flow for backup. I don't tow with propane tanks open so it was beeping at us to let us know it still wasn't running. So, I finally get it starting to cool down, but now we realize it will be hours till the fridge is ready to use. Okay, we have a backup electric Coleman cooler we had gotten ready just in case. Store the food in that and run it in the truck of the DC power.
We finally get loaded, on the road, and to our campground. Back in, and start levelling. The last jack to stabilize... damaged! (again, rushed walk-through) Played with it a bit, and got it down, but I don't know it actually did much, it still felt loose. And by now of course, it's getting dark.
So, Monday, our first day, was a bit stressful.
We get into camping, go to cook... and the only ventilation is the windows. The vent in the roof has a fan that works, but the crank handle to open the vent, not supplied. The outdoor cook stove? Not supplied. The rental place keeps them so that at the end of the season they can sell the camper with all the add-ons intact.
PS Do all RV AC units sound like a jet engine the entire time they run?
Wednesday or Thursday I attempted to figure out why the black water tank was smelling (we had used it a bit, but mostly the camp bathhouse). Emptied the tank, yet still saw stuff just below the toilet. Using a stick, I cleared the clog that we'd towed with us from the rental place. Ah, so you are supposed to see clearly way down the pipes.
Thursday evening my wife goes to start dinner, notices a puddle under the sink. The PEX fittings were leaking. Called the after hours number, left a message, and the fella told us somebody would come out the next day... at some point.
The next day, at 7 AM, we wake up to a call from the service guy, he was on his way. Prompt service, the leak got fixed... but 7 AM on my vacation? One more note? Under the sink was a panel that was loose. It looked like it had been pulled off prior to our rental, and we had pointed it out during the walk-through. Well, this panel is right where you'd need to look to figure out where the leak was coming from!! :h
After that, Friday went pretty well. The weather got colder, so we nervously tried the furnace. It worked, but we didn't turn it up too high. Saturday was colder, we turned the furnace up... and it wouldn't work at all. Checked if we had propane and yes, we did. Check the 12V fuse, it was still good. Shut the furnace and thermostat down a while to reset it, and got it working a little more, then it conked out again. So, that was it. They had given us an extra day for the rental cause of the leak, but we took it back Sunday AM (our original return day) cause we were just done.
So... will we rent again? No, and definitely not from this place. Time to start looking for something of our own so that we can make sure it has what we expect. For now, we're trying to brush ourselves off and hopefully, laugh about it. Hope you had a good chuckle too. I really wonder what some of those other folks that rented the same day went through. :)
TL;DR; (Too Long, Didn't Read)
- Had to wait 2 hours at the rental location for the Trailer
- Had to clean the 'cleaned and inspected' trailer before loading
- Damaged levelling jack
- Fridge not cooling
- Water Leak
- Clogged black tank line
- Missing parts (ie. vent crank handle, outdoor stove)
- Furnace didn't work
