OldBlackWater's avatar
Jul 20, 2015
Overheating Toad!
I had a puzzling experience with my Ford C-Max Energi toad on the last day of my return trip from Yellowstone to Texas yesterday. After five hours on the road through the Texas heat (mid-to-upper 90s), we parked in a cement (i.e., not blacktop) mall parking lot to walk to a Whataburger, since that's what Texans must do when almost home from a long trip. After getting our fast food burger fix and returning to the motor home, I notice fluid leaking from the engine compartment of my C-Max. After opening the hood and whispering a couple of expletives (the kids were within earshot) to make my burning hands feel better, I see the fluid inside the coolant reservoir boiling and bubbling out onto the ground.
Before approaching the car, I had noticed that the fan motor was running in an attempt to cool itself down. I also noticed after starting the car that 12 miles had been added to the odometer, as if maybe on the road somewhere it turned itself on to try to cool down (or maybe that's just a totally unrelated quirk of the car).
My guess is that the engine compartment took on a lot of heat from the hot roads and from my motorhome, then baked some more in the hot sun for 30 minutes while we enjoyed the deliciousness of oversized burger patties on buttery toasted buns.
Has this ever happened to anyone else?
  • There are special considerations for towing a hybrid with 4 wheels down.
    Some models even recommend against doing it at all.
    If you have a hybrid, get the recommended procedure specific to your model.
    THE MILEAGE SHOULD NOT ACCUMULATE AND THE COOLANT TEMP. SHOULD NOT COME ANYWHERE NEAR THE 230 F OR SO IT TAKES TO OVERFLOW. Something is definitely amiss.....and it could turn out to be expensive in the end.
  • I assume you have read and follow these guidelines:
    Recreational Towing
    Note: Put your climate control system in
    recirculated air mode to prevent exhaust
    fumes from entering the vehicle. See
    Climate Control (page 107).
    Follow these guidelines if you have a need
    for recreational (RV) towing. An example
    of recreational towing would be towing
    your vehicle behind a motorhome. We
    designed these guidelines to prevent
    damage to your transmission.
    You can tow your vehicle with all four
    wheels on the ground or with the front
    wheels off the ground by using a tow dolly.
    If you are using a tow dolly follow the
    instructions specified by the equipment
    provider.
    If you tow your vehicle with all four wheels
    on the ground:
    • Tow only in the forward direction.
    • Release the parking brake.
    Vehicles with Push Button Start
    1. Start the vehicle by pressing the brake
    pedal, and then pressing the ENGINE
    START/STOP button until the vehicle
    starts.
    2. Press the brake pedal and shift the
    transmission into position N.
    3. Turn the vehicle off by pressing the
    ENGINE START/STOP button once.
    (Trip Summary appears in the left
    instrument cluster screen when the
    vehicle is off.)
    Note: You can remove the key fob from the
    vehicle while towing
    Vehicles with Ignition Key
    pedal, and then turning the ignition key
    until the vehicle starts.
    3. Turn the vehicle off by turning the
    ignition key past the accessory position.
    The key position is between the
    accessory and off positions. See
    Ignition Switch (page 127). (Trip
    vehicle is off.)
    Note: If your vehicle is equipped with an
    ignition key, you cannot remove the key from
    the ignition cylinder when the transmission
    is in position N and the vehicle is off.
    All Vehicles
    • Do not exceed 70 mph (113 km/h).
    • Place the transmission in position P,
    start the vehicle, and allow the engine
    to run for one minute at the beginning
    of each day (you may need to press the
    accelerator pedal in order to start the
    engine). After allowing the vehicle to
    run, place the transmission back into
    position N and the ignition in the off
    position.
    Note: A SHIFT TO PARK or
    TRANSMISSION NOT IN PARK message
    may appear in the information display when
    the transmission is in position N and the
    ignition is in the off position.
  • I dont know anything about towing a vehicle beind an rv, but i belive i C-max is a hybrid. My understanding of a hybrid is that if you are not acelerating the wheels are generating energy to charge the batties? I would assume the car is in neutral with the key in the acc. Position or is there a way to put it in neutral and still get the key into off position?
  • How does the radiator look? Could you have picked up some substance (mud, tar, cottonwood duff, etc) that caused the overheat?
  • It sounds to me like the engine was turning over while being towed and the engine to heated up. Since you mentioned the additional 12 miles I'll assume your toad usually doesn't accumulate miles while being toad. It that's correct, then that's an additional clue that the engine was being turned over from being towed.
    I don't think hot pavement would cause the problem or else people's cars would overheat from just being parked in a paved parking lot during the afternoon.
    Bill
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
