jlrmfc21's avatar
jlrmfc21
Overnight stops and Rest Areas
Hi all,
We have a trip planned from Michigan to Florida to stay a week at Fort Wilderness. To maximize our time, I think we will probably stay overnight at a Rest Area on the way down. I have a few questions regarding this:
1. First, is this safe anymore and allowed?
2. Slide outs - Can we put out the slide out at a rest area?
3. Battery and 7 Pin - Do you leave the 7 pin wiring hooked up to the TV? I would assume, No, as to not drain the vehicle battery. I'm also assuming that my regular battery would power the slide and all lights.
4. TT - 2018 Jayco Whitehawk 29BH - Is it ok to use my stabilizer jacks at a rest area?
Would like to hear folks opinions/recommendations to those who have stayed at Rest Areas.
thanks
  • SidecarFlip wrote:
    ...and no rest areas near urban areas either. Those rest areas are populated by 'ladies of the night' at night, looking for lonely truckers.
    Floosie’s? :E
  • ...and no rest areas near urban areas either. Those rest areas are populated by 'ladies of the night' at night, looking for lonely truckers.
  • 1. Safe: pretty safe, yes. Truckers do it all the time. Allowed: varies by state. You'll have to check. The rules may be different for truckers, presumably under the notion that they know the rules about dumping waste water (don't do that) and the like.
    2. If you don't interfere with the space next to you, then yes. If you interfere with the space next to you, likely no. Many rest areas fill up with trucks at night. It would make it obvious you're over-nighting.
    3. No. Should you use enough power to drain the battery, you wouldn't want to not be able to start the car in the morning. That said, unless you run the furnace or watch TV all night, you're not likely to use that much power.
    4. Yes. Put something under them (board, orange plastic jack pads, something like that) so that you don't damage the blacktop. That's just politeness.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
