nharinton's avatar
nharinton
Overtight weight distribution brackets bent frame....
Picked up a 28' 1991 Cobra travel trailer a few weeks ago. took it camping the weekend we bought it and then home. Pulled great. When unhitching the trailer I noticed this. Not sure if I did this or if it was like this, but I didn't notice it when we bought the camper. Its seems like the brackets were tightened down so much the frame is dented/bent and the brackets are bent. The brackets were on the trailer when I bought it and i did not mess with em.
Is this repairable? Could I weld on some plating to reinforce the frame. Really don't want to put that much $$ into the trailer to replace the beams.....
Thanks all!
  • It seems that there is a lot more going on there than over tight saddle brackets. I see where the saddle bolt was tightened down too tight but the top of the frame looks distorted as well. I'm seeing alot of rust. I assume that is a box frame? considering the age of the trailer, I would be concerned that the frame is rusting from the inside and the metal is weakened.
    I would have the entire A frame replaced by a professional welder. Not as expensive as you might think.
    Any idea what your tongue weight is?
  • It looks like the previous owner over tightened the saddle bolts against the frame. Those bolts are only meant to snug up to the frame just to hold the saddles in place.
    I don't see a problem with adding / welding some flat steel plate on.
  • Yeah welding isn't an issue. Just wanted to double check that welding on the frame is not a terrible idea.
  • You could add a section of flat stock 15-24 inches long 3/8 inch thick to reinforce the frame and not even weld it on. Could use a couple of bolts to hold in place.
    Yes, welding it on would be ultimate solution. Need a good welder so as not to blow through stock frame.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
