phipps33's avatar
phipps33
P2 Controller Issue
I purchased a P2 brake controller used off eBay.
I have a question as to how it works when no trailer is attached. At first mine simply showed a screen with the 2 dots and would do nothing when the brakes were applied. If I moved the manual lever it would show NC. I believe this is how it is supposed to work.
Fast forward to this weekend. I pulled our camper to our local campground and all seemed to be working fine. Camper brakes worked great. I disconnected the camper and it started showing NC all the time except when you hit the brakes then it would show the 2 dots nothing else. When I shut the truck off and it sat it never went into low power mode.
Is my controller bad? I've double checked all the wiring at the controller, under the dash and at the rear connector. Everything looks good. I pulled the fuse and reinstalled it and it seems to functioning as before, but I haven't reconnected the camper yet.
Second question, when applying the brakes while driving how how should the displayed voltage to? Mine never got over 2-3 volts, most of the time it was 1.5-2. The trailer seemed to be braking fine and wasn't pushing the truck. I'm guessing I'm just not knowledgeable enough on how controllers work. My last one didn't have a display so I had no way of knowing output voltage.
I'm hoping you wise people can help me out with my questions.
Thanks,
Gary
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
