thermographer's avatar
Apr 08, 2016
Paneling nails for aluminum frame?
I had a water leak on both front sides of the TT, and had to remove the paneling and wet insulation. I got the leak stopped and everything left open to dry for a few months and ready to go back together.
My question is, what to use for paneling nails into the aluminum frame. The original paneling was nailed at the very bottom and top under molding, with something along the lines of liquid nails or other bonding on the middle rails.
I have an Arrow ETFX50 electric staple and nail gun but never tried the nails yet. Its great for repairing my screen porch, but not quite sure the aluminum frame will be that easy. Any suggestions will be appreciated. Thanks.
  • Well what a difference a day makes. Talking to SWMBO (she who must be obeyed), she didn't want to see visible self tapping screws.
    I took RoyB's advise and I went to Home Depot (closer than Lowes) and got a battery powered 16ga nailer.
    I used small dabs of liquid nails across the aluminum frame and the nailer to hold in place to keep it from sagging.
    I'll post pictures once I get the paint and trim work up. Thanks for all the advise, without it, I might have skipped the adhesive
  • Unless the aluminum frame is wood-backed, a nail or staple is of no use. Screws made to attach to metal and adhesive would be your best bet. You could also attach some ledgers or other pieces of wood between/onto the aluminum frames but that seems like a lot of work and will take up insulation space.
  • DrewE's avatar
    DrewE
    Explorer III
    Adhesive is a great option. I've used Loctite PL FastGrab Premium in a similar situation and it makes a very strong if not permanent bond between aluminum and whatever. Unlike some construction adhesives, this particular one is recommended for use on foam insulation, which may or may not be important to you depending on what sort of insulation your trailer has.
    Aluminum extrusions in general can often be drilled and screwed and so forth rather similarly to wood. Sheet metal screws would be one option, though they might tend to work loose. Although their appearance isn't always the best, lath screws (Teks is one brand) can be handy because they have big flat heads that secure paneling decently without pulling through the thin plywood.
  • There is a reason they don't use nails, they won't hold, Use adhesive. Even screws will back out. Where they hang cabinets most use wood inside the aluminum so the screw has something to hold it in place.
  • I would use self tapping screws. If they didn't work because the aluminum was too thick I have drilled pilot holes with SST screws. They won't rust and don't look bad either.
  • RoyB's avatar
    RoyB
    Explorer III
    My hat is off to you for ripping out the panels yourself.. Would be gutsy move for me haha
    I would look for fastners with the ribbed shanks for aluminum frames... The more pronounced ribs the better...
    Something like this google image - I don't think these ribs shown are not really pronounced enough for aluminun framing
    It might require a screw instead at least in the four corners... A quick trips to LOWES should fix you right up haha... I always found those guys with a wealth of info along this line
    Roy Ken
