naturist
Aug 05, 2014Nomad II
bid_time wrote:
Overdrive is not the same as Torque Converter Lockup. Overdrive is a gear with a higher than 1:1 ratio. Locking out a gear simply means it's a gear you don't allow your transmission to shift into. It's normally done with the gear selector lever.
I agree with Bruce: Best answer.
I have no idea about the OPs transmission or controls available for it. I know about mine: 5 speed, with gears 4 and 5 being overdrive gears. It has an "Overdrive off" button that restricts the transmission to gears 1 thru 3, that is, it "locks out" the overdrive, making gears 4 and 5 unavailable. This is useful for dragging heavy stuff up steep inclines, when the transmission (programmed to give best mileage) would otherwise try to do the job in too high a gear.
The usual transmission programming does not have the engine locked into a single gear when you select D1, D2, D3, etc. instead of D. If you choose D3 on a 4 speed transmission, what you have done is simply lock the transmission out of 4th gear. It will behave normally at speeds below those at which it would shift to 4th, but will stay in 3rd and never shift into 4th at higher speeds. This is what is meant by "lock out."
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
