CarnationSailor's avatar
Feb 16, 2021
Patching Coroplast
Our 5th has coroplast covering the bottom of it. The factory cut a 8 - 10 inch slit in it to route a power cable thru it. The original tape job fell off after about a year, and now after 2 or 3 redos with Gorilla tape, I cannot get a tape patch to last longer than about 4 months.
The coroplast is now coated with dirt/dust-imbedded adhesive residue which is probably why the tape doesn't stick very well. Not sure how I would get the coroplast cleaned up as it just pushes up when any pressure is applied to it - same problem when applying tape.
Any ideas?
    Any ideas?
    try clean it up with denatured alchol, that should clean it up nice. you can also put a backing material in there like thin plywood and then screw the coraplast for that then seal it. might last a bit longer.
    Steve
